code will not upload
Hi
I have one of these and when I used it before I could upload to it.
spark fun product : sen 10736
now depreciated can still be found on the website
https://www.sparkfun.com/products/retired/10736 <https://www.sparkfun.com/products/retired/10736>
the unit is working and outputting data but I can not upload any changes to the code
here is the error message.
I am following the instructions here
Tutorial on setting up the DOF 9 Razor
https://github.com/Razor-AHRS/razor-9do … i/Tutorial <https://github.com/Razor-AHRS/razor-9do … i/Tutorial>
if I can not upload the item is useless . Can you tell me what to do to resolve this
I do not want to buy th new version until I understand why this one does not now upload
egards
Max
Arduino: 1.8.8 (Mac OS X), Board: “Arduino Pro or Pro Mini, ATmega328P (3.3V, 8 MHz)”
/Applications/Arduino 1.8.8.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino 1.8.8.app/Contents/Java/hardware -hardware /Users/maxbirley/Library/Arduino15/packages -hardware /Users/maxbirley/Dropbox/Arduino/hardware -tools /Applications/Arduino 1.8.8.app/Contents/Java/tools-builder -tools /Applications/Arduino 1.8.8.app/Contents/Java/hardware/tools/avr -tools /Users/maxbirley/Library/Arduino15/packages -built-in-libraries /Applications/Arduino 1.8.8.app/Contents/Java/libraries -libraries /Users/maxbirley/Dropbox/Arduino/libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10808 -build-path /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539 -warnings=none -build-cache /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_cache_751817 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino
/Applications/Arduino 1.8.8.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino 1.8.8.app/Contents/Java/hardware -hardware /Users/maxbirley/Library/Arduino15/packages -hardware /Users/maxbirley/Dropbox/Arduino/hardware -tools /Applications/Arduino 1.8.8.app/Contents/Java/tools-builder -tools /Applications/Arduino 1.8.8.app/Contents/Java/hardware/tools/avr -tools /Users/maxbirley/Library/Arduino15/packages -built-in-libraries /Applications/Arduino 1.8.8.app/Contents/Java/libraries -libraries /Users/maxbirley/Dropbox/Arduino/libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10808 -build-path /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539 -warnings=none -build-cache /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_cache_751817 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino
Using board ‘pro’ from platform in folder: /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23
Using core ‘arduino’ from platform in folder: /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23
WARNING: Category ‘sensors’ in library SparkFun BQ72441 LiPo Fuel Gauge Arduino Library is not valid. Setting to ‘Uncategorized’
WARNING: Category ‘Sensor’ in library SparkFun DS3234 Real-Time Clock (RTC) is not valid. Setting to ‘Uncategorized’
Detecting libraries used…
/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/sketch/Razor_AHRS.ino.cpp -o /dev/null
/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/sketch/Razor_AHRS.ino.cpp -o /dev/null
/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src/Wire.cpp -o /dev/null
/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src/utility/twi.c -o /dev/null
Generating function prototypes…
/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/sketch/Razor_AHRS.ino.cpp -o /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/preproc/ctags_target_for_gcc_minus_e.cpp
“/Applications/Arduino 1.8.8.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch…
/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/sketch/Razor_AHRS.ino.cpp -o /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_70539/sketch/Razor_AHRS.ino.cpp.o
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino: In function ‘void read_sensors()’:
Razor_AHRS:456:13: error: ‘Read_Gyro’ was not declared in this scope
if (!reset_calibration_session_flag) return;
Razor_AHRS:457:14: error: ‘Read_Accel’ was not declared in this scope
Razor_AHRS:458:13: error: ‘Read_Magn’ was not declared in this scope
// Reset acc and mag calibration variables
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino: In function ‘void reset_sensor_fusion()’:
Razor_AHRS:478:43: error: ‘Vector_Cross_Product’ was not declared in this scope
Razor_AHRS:486:19: error: ‘Compass_Heading’ was not declared in this scope
while (Serial.available() < 1) { } // Block
Razor_AHRS:490:52: error: ‘init_rotation_matrix’ was not declared in this scope
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino: In function ‘void setup()’:
Razor_AHRS:568:12: error: ‘I2C_Init’ was not declared in this scope
if (values_param == ‘r’) // Output _r_aw sensor values
Razor_AHRS:569:14: error: ‘Accel_Init’ was not declared in this scope
output_mode = OUTPUT__MODE_SENSORS_RAW;
Razor_AHRS:570:13: error: ‘Magn_Init’ was not declared in this scope
else if (values_param == ‘c’) // Output _c_alibrated sensor values
Razor_AHRS:571:13: error: ‘Gyro_Init’ was not declared in this scope
output_mode = OUTPUT__MODE_SENSORS_CALIB;
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino: In function ‘void loop()’:
Razor_AHRS:699:91: error: ‘output_calibration’ was not declared in this scope
Razor_AHRS:707:23: error: ‘Compass_Heading’ was not declared in this scope
Razor_AHRS:708:21: error: ‘Matrix_update’ was not declared in this scope
Razor_AHRS:709:17: error: ‘Normalize’ was not declared in this scope
Razor_AHRS:710:24: error: ‘Drift_correction’ was not declared in this scope
Razor_AHRS:711:20: error: ‘Euler_angles’ was not declared in this scope
Razor_AHRS:713:63: error: ‘output_angles’ was not declared in this scope
Razor_AHRS:717:64: error: ‘output_sensors’ was not declared in this scope
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/DCM.ino: In function ‘void Normalize()’:
DCM:12:65: error: ‘Vector_Dot_Product’ was not declared in this scope
error= -Vector_Dot_Product(&DCM_Matrix[0][0],&DCM_Matrix[1][0])*.5; //eq.19
DCM:14:58: error: ‘Vector_Scale’ was not declared in this scope
Vector_Scale(&temporary[0][0], &DCM_Matrix[1][0], error); //eq.19
DCM:17:67: error: ‘Vector_Add’ was not declared in this scope
Vector_Add(&temporary[0][0], &temporary[0][0], &DCM_Matrix[0][0]);//eq.19
DCM:20:74: error: ‘Vector_Cross_Product’ was not declared in this scope
Vector_Cross_Product(&temporary[2][0],&temporary[0][0],&temporary[1][0]); // c= a x b //eq.20
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/DCM.ino: In function ‘void Drift_correction()’:
DCM:54:77: error: ‘Vector_Cross_Product’ was not declared in this scope
Vector_Cross_Product(&errorRollPitch[0],&Accel_Vector[0],&DCM_Matrix[2][0]); //adjust the ground of reference
DCM:55:72: error: ‘Vector_Scale’ was not declared in this scope
Vector_Scale(&Omega_P[0],&errorRollPitch[0],Kp_ROLLPITCH*Accel_weight);
DCM:58:44: error: ‘Vector_Add’ was not declared in this scope
Vector_Add(Omega_I,Omega_I,Scaled_Omega_I);
/Users/maxbirley/Dropbox/Arduino/Razor_AHRS/DCM.ino: In function ‘void Matrix_update()’:
DCM:85:53: error: ‘Vector_Add’ was not declared in this scope
Vector_Add(&Omega[0], &Gyro_Vector[0], &Omega_I[0]); //adding proportional term
DCM:110:60: error: ‘Matrix_Multiply’ was not declared in this scope
Matrix_Multiply(DCM_Matrix,Update_Matrix,Temporary_Matrix); //a*b=c
Using library Wire at version 1.0 in folder: /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire
exit status 1
Invalid library found in /Users/maxbirley/Dropbox/Arduino/libraries/i2cdevcollection: no headers files (.h) found in /Users/maxbirley/Dropbox/Arduino/libraries/i2cdevcollection
Invalid library found in /Users/maxbirley/Dropbox/Arduino/libraries/minimu9_AHRS: no headers files (.h) found in /Users/maxbirley/Dropbox/Arduino/libraries/minimu9_AHRS
Invalid library found in /Users/maxbirley/Dropbox/Arduino/libraries/SabertoothArduinoLibraries: no headers files (.h) found in /Users/maxbirley/Dropbox/Arduino/libraries/SabertoothArduinoLibraries
Hi Max.
Arduino is never getting to the upload process because the code isn’t compiling.
The errors you’re seeing indicate you haven’t installed the libraries needed for the sensor chip on the board and that’s why the code isn’t compiling. You need to download and install the libraries for the following IC’s:
  • - ITG3200
  • - ADXL345
  • - HMC5883L
  • We have libraries for the ITG and ADXL [here and a library for the HMC [here.
    The library manager should be able to install the HMC5883L library but the other two are pretty old and will need to be installed into Arduino manually.](GitHub - jarzebski/Arduino-HMC5883L: HMC5883L Triple Axis Digital Compass Arduino Library)](GitHub - sparkfun/IMU_Digital_Combo_Board: A simple breakout for the ADXL345 accelerometer and the ITG-3200 MEMS gyro. (https://www.sparkfun.com/products/10121))
    Very helpful. As it was working before I thought the libraries were installed. Many thanks
    ok the libraries are all loaded. When I use the example code for each ic separately they all work. when I try to compile with the razor IMUs code it fails with the following. So it seems the board is ok but the code is not working with the libraries…any thoughts
    most appreciated
    /Applications/Arduino 1.8.8.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino 1.8.8.app/Contents/Java/hardware -hardware /Users/maxbirley/Library/Arduino15/packages -hardware /Users/maxbirley/Dropbox/Arduino/hardware -tools /Applications/Arduino 1.8.8.app/Contents/Java/tools-builder -tools /Applications/Arduino 1.8.8.app/Contents/Java/hardware/tools/avr -tools /Users/maxbirley/Library/Arduino15/packages -built-in-libraries /Applications/Arduino 1.8.8.app/Contents/Java/libraries -libraries /Users/maxbirley/Dropbox/Arduino/libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10808 -build-path /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696 -warnings=none -build-cache /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_cache_516120 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino
    /Applications/Arduino 1.8.8.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino 1.8.8.app/Contents/Java/hardware -hardware /Users/maxbirley/Library/Arduino15/packages -hardware /Users/maxbirley/Dropbox/Arduino/hardware -tools /Applications/Arduino 1.8.8.app/Contents/Java/tools-builder -tools /Applications/Arduino 1.8.8.app/Contents/Java/hardware/tools/avr -tools /Users/maxbirley/Library/Arduino15/packages -built-in-libraries /Applications/Arduino 1.8.8.app/Contents/Java/libraries -libraries /Users/maxbirley/Dropbox/Arduino/libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10808 -build-path /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696 -warnings=none -build-cache /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_cache_516120 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/maxbirley/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Users/maxbirley/Dropbox/Arduino/Razor_AHRS/Razor_AHRS.ino
    Build options changed, rebuilding all
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src/Wire.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src/utility/twi.c -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Dropbox/Arduino/libraries/gy-88/BMP085.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Dropbox/Arduino/libraries/gy-88/I2Cdev.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Dropbox/Arduino/libraries/gy-88/MPU6050.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Dropbox/Arduino/libraries/ITG3200/ITG3200.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Dropbox/Arduino/libraries/ADXL345/ADXL345.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L/HMC5883L.cpp -o /dev/null
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/preproc/ctags_target_for_gcc_minus_e.cpp
    “/Applications/Arduino 1.8.8.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/preproc/ctags_target_for_gcc_minus_e.cpp
    Compiling sketch…
    /Users/maxbirley/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10808 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/Users/maxbirley/Library/Arduino15/packages/arduino/hardware/avr/1.6.23/libraries/Wire/src -I/Users/maxbirley/Dropbox/Arduino/libraries/gy-88 -I/Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 -I/Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 -I/Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp -o /var/folders/tm/05gm32_j4g92jgb80dx_nl7c0000gn/T/arduino_build_131696/sketch/Razor_AHRS.ino.cpp.o
    Razor_AHRS:464:13: error: ‘Read_Gyro’ was not declared in this scope
    Razor_AHRS:465:14: error: ‘Read_Accel’ was not declared in this scope
    Razor_AHRS:466:13: error: ‘Read_Magn’ was not declared in this scope
    Razor_AHRS:486:43: error: ‘Vector_Cross_Product’ was not declared in this scope
    Razor_AHRS:494:19: error: ‘Compass_Heading’ was not declared in this scope
    Razor_AHRS:498:52: error: ‘init_rotation_matrix’ was not declared in this scope
    Razor_AHRS:576:12: error: ‘I2C_Init’ was not declared in this scope
    Razor_AHRS:577:14: error: ‘Accel_Init’ was not declared in this scope
    Razor_AHRS:578:13: error: ‘Magn_Init’ was not declared in this scope
    Razor_AHRS:579:13: error: ‘Gyro_Init’ was not declared in this scope
    Razor_AHRS:707:91: error: ‘output_calibration’ was not declared in this scope
    Razor_AHRS:715:23: error: ‘Compass_Heading’ was not declared in this scope
    Razor_AHRS:716:21: error: ‘Matrix_update’ was not declared in this scope
    Razor_AHRS:717:17: error: ‘Normalize’ was not declared in this scope
    Razor_AHRS:718:24: error: ‘Drift_correction’ was not declared in this scope
    Razor_AHRS:719:20: error: ‘Euler_angles’ was not declared in this scope
    Razor_AHRS:721:63: error: ‘output_angles’ was not declared in this scope
    Razor_AHRS:725:64: error: ‘output_sensors’ was not declared in this scope
    Using library gy-88 in folder: /Users/maxbirley/Dropbox/Arduino/libraries/gy-88 (legacy)
    Using library ITG3200 in folder: /Users/maxbirley/Dropbox/Arduino/libraries/ITG3200 (legacy)
    Using library ADXL345 in folder: /Users/maxbirley/Dropbox/Arduino/libraries/ADXL345 (legacy)
    Using library HMC5883L in folder: /Users/maxbirley/Dropbox/Arduino/libraries/HMC5883L (legacy)
    exit status 1
    It doesn’t look like the libraries installed correctly.
    The " was not declared in this scope " errors you’re seeing indicate that Arduino isn’t able to see the libraries that call those functions.
