hello
I tested your configuration, it is the good thanks,
I am always on the LCD, the output are compatible with the control words but my LCD still off
I you joint the code
#include “lpc21xx_keil.h”
#define LCD_D0 17 //P1.16
#define LCD_D1 18 //P1.17
#define LCD_D2 19 //P1.18
#define LCD_D3 20 //P1.19
#define LCD_D4 21 //P1.20
#define LCD_D5 22 //P1.21
#define LCD_D6 23 //P1.22
#define LCD_D7 24 //p1.23
#define LCD_RS 28 //P0.28
#define LCD_RW 29 //P0.29
#define LCD_EN 30 //P0.30
#define LCD_DATA ((1<<LCD_D0)|(1<<LCD_D1)|(1<<LCD_D2)|(1<<LCD_D3)|(1<<LCD_D4)|(1<<LCD_D5)|(1<<LCD_D6)|(1<<LCD_D7))
#define LCD_COM ((1<<LCD_RS)|(1<<LCD_RW)|(1<<LCD_EN))
#define lcd_rs_set() IOSET0 = (1<<LCD_RS)
#define lcd_rs_clr() IOCLR0 = (1<<LCD_RS)
#define lcd_en_set() IOSET0 = (1<<LCD_EN)
#define lcd_en_clr() IOCLR0 = (1<<LCD_EN)
#define lcd_rw_set() IOSET0 = (1<<LCD_RW)
#define lcd_rw_clr() IOCLR0 = (1<<LCD_RW)
void out(unsigned char);
void lcd_control(unsigned char);
void lcd_putchar(unsigned char);
void lcd_print(unsigned char*);
void wait(){
int loop=2800;
while(loop–);
void out(unsigned char val)
IOCLR1 = (LCD_DATA);
IOSET1 =((val)&0xff)<<LCD_D0;
wait();
void lcd_control(unsigned char val){
lcd_rs_clr();
out(val);
void lcd_init()
lcd_rs_clr();
lcd_rw_clr();
lcd_en_set();
wait();
wait();
lcd_control(0x38);
lcd_control(0x30);
lcd_control(0x30);
lcd_control(0x30);
lcd_control(0x02);
wait();
lcd_control(0x0E);
lcd_control(0x01);
lcd_control(0x06);
void lcd_putchar(unsigned char c)
lcd_rs_set();
out(c);
void lcd_print(unsigned char* str)
int i;
for (i=0;i<16 && str*!=0;i++)*
lcd_putchar(str);
main(void)
PINSEL1 = 0x00000000; //IO
PINSEL2 = 0x0; //IO
IODIR0 = (LCD_COM); //SORTIE
IODIR1 = (LCD_DATA); //SORTIE
///////////////////////// configuration PLL///////////////////////////////////////
* MAMCR = 2; // accelerateur memoir activé*
* PLLCFG = 0x23;// calcul de frequence , CPU a 64 Mhz*
* PLLFEED = 0xAA;// application de pllcfg*
* PLLFEED = 0x55;// application de pllcfg*
* PLLCON = 0x1;//activation pll*
* while(!(PLLSTAT & 0x400)){}*
* PLLCON=0x3;//connexion pll*
* PLLFEED=0xAA;*
* PLLFEED=0x55;*
lcd_init();
lcd_print(“hello”);
