I wanted to verify that I am connecting to the COM-10917 surface transducer correctly and that nothing is wrong with the setup.
I measured the impedance across the pads on the PCB portion of and got 4.5 ohms which is a bit different from what is listed on the features page.
I attempted to connect waveform generator with a 3 Vpp square wave signal at 400 Hz to the PCB leads but did not see any responses from the transducers. There were no signs of vibrations.
I managed to get it working with the waveform generator using 4 Vpp and switching to a square wave. The sine pattern was not enough to get a noticeable response.
