COM-11951 GTE Knob - Small
I have a question about the mechanical details of the COM-11951 knob. I would like to use it with a Bourns encoder, but I don’t know how long to specify the shaft length. The datasheet does not have detail about the depth of the 6mm hole, and where the set screw is located. I would also like to know if there is an inset around the hole where the bushing of the encoder could fit when the knob is placed over the shaft.
Thanks and best regards,
Greg
I just looked through the pictures on the website, and I see there is an inset. I would be most appreciative if you could measure the depth of the inset and the depth of the 6mm hole for the shaft. It appears the set screw is located pretty close the base of the inset.
Greg
