compile problems with AS7263 sensor
The example code for this sensor compiles just fine with UNO, etc., but when I try to add other sensors, like your RGB sensor and an AS7262 from a different vendor I get these compiler messages. Can you tell what’s going on here? and how to fix it? Is there some unavoidable conflict among these sensors? Yes, I have the sensors connected to a multiplexer because AS7262 and AS7263 have the same fixed I2C address.
In file included from C:\Users\David.000\Documents\Arduino\MultiSpectralNew\MultiSpectralNew.ino:9:0:
C:\Users\David.000\Documents\Arduino\libraries\SparkFun_AS726X\src/AS726X.h:99:22: error: expected identifier before numeric constant
#define AS7262_V_CAL 0x14
C:\Users\David.000\Documents\Arduino\libraries\Adafruit_AS726X/Adafruit_AS726x.h:61:3: note: in expansion of macro ‘AS7262_V_CAL’
AS7262_V_CAL = 0x14,
C:\Users\David.000\Documents\Arduino\libraries\SparkFun_AS726X\src/AS726X.h:99:22: error: expected ‘}’ before numeric constant
C:\Users\David.000\Documents\Arduino\libraries\SparkFun_AS726X\src/AS726X.h:99:22: error: expected unqualified-id before numeric constant
In file included from C:\Users\David.000\Documents\Arduino\MultiSpectralNew\MultiSpectralNew.ino:11:0:
C:\Users\David.000\Documents\Arduino\libraries\Adafruit_AS726X/Adafruit_AS726x.h:67:1: error: expected declaration before ‘}’ token
exit status 1
Error compiling for board Arduino Uno.
It is surely a problem to mix Adafruit and Sparkfun libraries for the same sensors. Choose one or the other.
Please post the code (using code tags), links to the product pages for the actual boards you have, and a wiring diagram.
