I am trying to use the Example1_Basic_Temperature_Readings with a LilyGo S3 T-Display, but I am getting the following error during compilation. Any ideas on how to fix that?
In file included from /Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/xtensa/include/xtensa/xtruntime.h:30,
from /Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/freertos/port/xtensa/include/freertos/portmacro.h:40,
from /Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/freertos/include/freertos/portable.h:51,
from /Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/freertos/include/freertos/FreeRTOS.h:63,
from /Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/cores/esp32/Arduino.h:33,
from /private/var/folders/j0/_j5h8rw161l2lrx2khy0_2wh0000gn/T/arduino/sketches/02B15C0E170C7D1061C0B5BBB4C1B090/sketch/Example_01_BasicReadings.ino.cpp:1:
/Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/xtensa/esp32s3/include/xtensa/config/specreg.h:84:19: error: expected identifier before numeric constant
#define INTERRUPT 226
/Users/alexsouza/Documents/Arduino/libraries/SparkFun_AS6212_Qwiic_Arduino_Library/src/registers/AS6212_Registers.h:42:3: note: in expansion of macro 'INTERRUPT'
INTERRUPT = 0x0100, //9
/Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/xtensa/esp32s3/include/xtensa/config/specreg.h:84:19: error: expected '}' before numeric constant
In file included from /Users/alexsouza/Documents/Arduino/libraries/SparkFun_AS6212_Qwiic_Arduino_Library/src/SparkFun_AS6212_Qwiic.h:32,
from /private/var/folders/j0/_j5h8rw161l2lrx2khy0_2wh0000gn/T/.arduinoIDE-unsaved20231110-49824-ltmbd3.wjjsi/Example_01_BasicReadings/Example_01_BasicReadings.ino:40:
/Users/alexsouza/Documents/Arduino/libraries/SparkFun_AS6212_Qwiic_Arduino_Library/src/registers/AS6212_Registers.h:24:21: note: to match this '{'
enum AS6212_Register{
/Users/alexsouza/Library/Arduino15/packages/esp32/hardware/esp32/2.0.14/tools/sdk/esp32s3/include/xtensa/esp32s3/include/xtensa/config/specreg.h:84:19: error: expected unqualified-id before numeric constant
/Users/alexsouza/Documents/Arduino/libraries/SparkFun_AS6212_Qwiic_Arduino_Library/src/registers/AS6212_Registers.h:47:1: error: expected declaration before '}' token
exit status 1
Compilation error: exit status 1
