hi
what is the minimum distance needed for a 0.4\0.2 component to the v-cut line ?
same question for 0.2\0.1 component
thanks
ilan
hi
thanks
ilan
Depends what component it is.
If its a COG ceramic cap then I’d say 5mm to prevent stress when descoring.
Otherwise its good practice to keep as clear as possible, about 1mm should do.
Depends on your descoring methods & equipment.
