I am using the latest Eagle PCB package,
In the library, i notice that many components have silk screen lines which are less then 0.3mm away from the pads.
Is it not true that PCB manufacturers cannot make PCB’s with this accuracy, and that what will happen is that the silk screen lines will unfortunately end up over the pads on the board when its made?
(silk screen lines over pads, is , i believe, a bad thing since it makes soldering to the pad more difficult?)
