My silk screen extends past the board outline. I understand this is a no-no:
However, the component outlines are correct -- the components were placed so they overhand the board. This also works out great for the assembly diagram.only the design data in the Gerbers and not extra text or other things outside of the design outline
The result, of course, is that I’m quoted a board size larger than the board itself. Is there an easy way to trim the silk screen to the board size without changing the component outlines? I’m using Eagle.
