I Ordered PCB From PCB Wing And I received This Error Can Anyone help Me please How To Fix it I’m New To Eagle I Don’t Reilly Know Where Are The Settings Of the silkscreen
Some silk screen of your PCBs are too small and their lines are
too thin to print. They'll be printed blur.
We recommend that they at least to be composed of 4mil thick line;
at least 25mil high, the only way they can be clearly printed.
You’ll need to smash the components first, then use Change to change the Size and Ratio. You can change them individually or group select the whole board. After you do all this, you’ll probably have to move the silkscreens to clear the components. 0.04 inch with a 15% ratio works well for most of my purposes.
Is there any way to easily remove isolated copper in Eagle? I’ve been trying to figure this out for a while. Or do I just have to be very specific when defining a polygon to make sure I don’t get isolated copper?
