Connect Pimoroni Fan SHIM for Raspberry Pi and SparkFun Qwiic HAT for Raspberry Pi to a RPi 4
Any special consideration when I wish to connect Pimoroni Fan SHIM for Raspberry Pi and SparkFun Qwiic HAT for Raspberry Pi to a Raspberry Pi 4 Model B?
Do they work with Raspberry Pi 4 Model B?
Do I need Raspberry Pi GPIO Tall Header - 2x20 between them?
Thanks a lot
Greetings. Thanks for the post.
The fan and qwiic HAT are compatible with the Pi 4.
Yeah, you will want to use a header booster if you are going to use the fan SHIM in combination with a HAT.
I would suggest this one here: https://www.sparkfun.com/products/14017
I hope this helps.
