connect rfd900 radio to gps rtk sma card
hello.
I beg your help I need all the possible information and diagram to connect the RFDesign radio model RFD900 to the SparkFun GPS-RTK-SMA Breakout - ZED-F9P card, Base and mobile.
I also need information and a connection diagram in the case of having the RTK base installed with a raspberry pi 4 together with the RFD900 radio. Thanks for your help and prompt response.
We have a lot of resources available https://www.sparkfun.com/products/16481#documents-tab but we’re not going to have one for that specific radio…but we have an example using a BT radio module https://learn.sparkfun.com/tutorials/gp … ion-source
You can follow that guide, but wire yours http://rfdesign.com.au/products/rfd900-modem/ with the relevant pins
https://learn.sparkfun.com/tutorials/se … 9MQAvD_BwE and https://learn.sparkfun.com/tutorials/ho … 9MQAvD_BwE might also be helpful if you’re new to setting one up
