Is there any way to control this linear servo https://www.actuonix.com/l16-140-150-6-r which requires a 5v signal, from the Arduino MKR 1010 Wifi board which has an operating voltage of 3.3v, using your level shifter https://www.sparkfun.com/products/12009 in-between the servo and the Arduino on the signal wire?
I’d like to power the linear servo from a separate power supply, with the signal wire & shared ground going to the board.
Are we using the best board for the job? We have pretty tight space limitations.
Thanks in advance for your insight and guidance.
