Controlling a Pico Buck with TLC59711
Has anyone controlled the Pico Buck with a TLC59711 or some other open drain IC. I’m having a hard time attaching a pullup resistor and getting the Pico to use the output pins on the TLC59711. Any advice?
Haven’t tried it and we don’t have one to test with but I would imagine a 330 ohm resistor connected between the TLC59711 and ground would do the trick. Just connect the PicoBuck’s signal in pin to the connection between the TLC59711 and the resistor.
