Converting IAR project file to eclipse or crossworks
HI,
I have some LPC2378STK samples but they where written in IAR kickstart.
I use eclipse and crossworks. Is there anyway to convert these?
I am assuming that propritary libraries have been used and thus the code would need altering to reflect this.
Any ideas?
I have the same problem… any help would be great.
I am glad to see other Crossworks users here! I am using Crossworks for ARM under Linux, and am just learning how to get around in it. I am planning to purchase a Personal License next month.
8-Dale
Hello to everybody, maybe I have something that could help you. I have just finished to write a tutorial about using open source tools for STR7xx development, in which I show how to install and use GNUARM, OpenOCD and Eclipse. Since I also used at first IAR IDE, I had the problem to convert IAR projects to Eclipse and I wrote a paragraph in my tutorial about how to do that.
I’ve just written a post on this forum in order to present my tutorial, its title is “Using Open source tools for STR7xx Cross Development”, there you can find every info.
Anyway I write here the link where you can download it:
http://www.intilinux.com/embedded/530/u … lopment-2/
At the end of the post you can download the tutorial. Even if you’re not interested in STR7xx development, maybe the paragraph about conversion IAR → Eclipse could help you. Let me know
Giacomo
Great, thank you!
Gene
Of course you have to pay attention to the fact I converted IAR projects to the model used by me, so I use my linker and startup files, but you can easily substitute them with yours. Bye bye
Giacomo
