I am converting from OCDRemote to OpenOCD. I want to be able to update the Flash via JTAG. I have encountered a strange situation.
Lets start with the configuration.
The board is custom. JTAG device is a Olimex Wiggler clone. Board JTAG connector has pull-up and pull-down according to the Olimex demo board schematics.
I just installed OpenOCD yesterday, so I think it is the latest at Rev 88.
The configuration file is:
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface parport
parport_port 0x378
parport_cable wiggler
jtag_speed 0
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target
#target arm7tdmi
target arm7tdmi little run_and_halt 0 arm7tdmi-s_r4
target_script 0 reset h2294_init.script
run_and_halt_time 0 30
working_area 0 0x40000000 0x40000 nobackup
#flash configuration
flash bank lpc2000 0x0 0x40000 0 0 lpc2000_v1 0 14765 calc_checksum
flash bank cfi 0x80000000 0x400000 2 2 0
After a power cycle of the board, I run
openocd-pp -d3 -f oocd_wig.cfg -l powerup.log
and get
Debug: jtag.c:1184 jtag_init():
Debug: parport.c:373 parport_init(): requesting privileges for parallel port 0x378…
Debug: parport.c:383 parport_init(): …privileges granted
Debug: parport.c:210 parport_reset(): trst: 0, srst: 0
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1070 jtag_reset_callback():
Debug: bitbang.c:223 bitbang_execute_queue(): statemove end in 0
Debug: bitbang.c:237 bitbang_execute_queue(): scan end in 0
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 3f
Debug: jtag.c:988 jtag_read_buffer(): fields[0].in_value: 3f
Error: jtag.c:1123 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 3f
If I run OCDRemote and then kill it and re-run OpenOCD
openocd-pp -d3 -f oocd_wig.cfg -l postocdremote.log
I get:
Debug: jtag.c:988 jtag_read_buffer(): fields[0].in_value: 31
Debug: openocd.c:98 main(): jtag init complete
Debug: arm7_9_common.c:651 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 0
Warning: arm7_9_common.c:675 arm7_9_assert_reset(): srst resets test logic, too
Debug: bitbang.c:205 bitbang_execute_queue(): reset trst: 1 srst 1
Debug: parport.c:210 parport_reset(): trst: 1, srst: 1
Debug: bitbang.c:251 bitbang_execute_queue(): sleep
Debug: arm7_9_common.c:714 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 2
Debug: bitbang.c:205 bitbang_execute_queue(): reset trst: 0 srst 0
Debug: openocd.c:102 main(): target init complete
Debug: openocd.c:106 main(): flash init complete
Debug: gdb_server.c:1115 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: arm7_9_common.c:777 arm7_9_halt(): target->state: reset
Debug: embeddedice.c:251 embeddedice_write_reg(): 9: 0xffffffff
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 3
Debug: embeddedice.c:251 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:251 embeddedice_write_reg(): 13: 0x000000f7
Debug: embeddedice.c:155 embeddedice_read_reg_w_check(): 1
Debug: bitbang.c:198 bitbang_execute_queue(): end_state: 8
Debug: bitbang.c:237 bitbang_execute_queue(): scan end in -1
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 02
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 0c
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: ffffffff
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 09
Debug: jtag.c:957 jtag_build_buffer(): fields[2].out_value: 01
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 0b
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 00000100
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 0c
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 000000f7
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 0d
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 00000000
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 01
Debug: jtag.c:957 jtag_build_buffer(): fields[2].out_value: 00
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 04
Debug: jtag.c:988 jtag_read_buffer(): fields[0].in_value: ffffffff
Debug: arm7_9_common.c:615 arm7_9_poll(): DBGACK set, dbg_state->value: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000000
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 00000005
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 00
Debug: arm7_9_common.c:907 arm7_9_debug_entry(): target entered debug from Thumb state
Debug: bitbang.c:198 bitbang_execute_queue(): end_state: 5
Debug: jtag.c:957 jtag_build_buffer(): fields[0].out_value: 01
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 00060006
Debug: bitbang.c:215 bitbang_execute_queue(): runtest 0 cycles, end in -1
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: fc38fc38
Debug: jtag.c:988 jtag_read_buffer(): fields[1].in_value: 00000000
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 1e621e62
Debug: jtag.c:988 jtag_read_buffer(): fields[1].in_value: 278f8787
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 00040004
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 00e200e2
Debug: arm7_9_common.c:911 arm7_9_debug_entry(): r0_thumb: 0x00000000, pc_thumb: 0xe1e1f1da
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: ffff0117
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 10010587
Debug: jtag.c:988 jtag_read_buffer(): fields[1].in_value: ffffffff
Debug: jtag.c:988 jtag_read_buffer(): fields[1].in_value: ffff8787
Debug: jtag.c:988 jtag_read_buffer(): fields[1].in_value: 013c7c3c
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 0000f087
Debug: jtag.c:957 jtag_build_buffer(): fields[1].out_value: 0000f1a7
Debug: jtag.c:988 jtag_read_buffer(): fields[1].in_value: c0000000
Error: armv4_5.c:186 armv4_5_mode_to_number(): invalid mode value encountered
Debug: arm7_9_common.c:934 arm7_9_debug_entry(): target entered debug state in Jazelle mode
Error: arm7_9_common.c:939 arm7_9_debug_entry(): cpsr contains invalid mode value - communication failure
Error: target.c:1011 handle_target(): couldn’t poll target, exiting
If I run the OpenOCD command line again it usually (not always) works correctly. I can telnet into OpenOCD remote and execute commands. Sometimes it takes 3-4 tried.
I tried different JTAG_SPEED Settings, and they make no difference. After the OCDRemote start & kill, JTAG_SPEED can be 0 and it works fine.
Any clue on how to work through this? So far I have put about 8 hours of research into this problem.
