I am working on a personal project where I want to be able to hot Swap relatively regularly a connector with at least 11 pins, carrying 12v components ranging from 0.XA to 3-4A.
I initially planned on using a gx16 connector, as they look really nice, and are rock solid, but I am also trying to reduce to a minimum the weight of my setup.
Thus I looked into traditional connectors power ratings and I thought the molex connectors could be an interesting alternative… But I’ve read that they really aren’t meant to be plugged / unplugged regularly and would probably break over time.
Could anyone tell me what kind of connectors there are out there that could match my requirements? How do you guys choose your connectors? There are so many of them out there, hard to know what’s best!
I have used them in a number of projects. They can be mated & demated frequently and are vibration-resistant due to the twist-lock feature, all at a reasonable price.
Note that like the Harting ones, you will need to purchase pins & a crimp tool (or solder cup pins) separately. The ones for 16g wire at the bottom of the page should handle your current easily.
I really like the CPC, very similar to the gx16 yet all plastic, and the four screw holes make it possible to mount it nicely =)
Thanks a lot, I think I’ll go for this one =)
Although, I can’t find any datasheet, all links are broken on their websites… and I have a hard time finding a reseller that really shows what I’m buying, can’t figure out if it’s the male connector only, if it’s sold with both…?
If you get the crimp versions, get a good crimping tool, otherwise buy solder cup pins.
lagarkane:
Awesome!
