This is my first time creating footprints for eagle and I was hoping to get some feedback on the footprint I made for the TI LM5113. It is a small DSBGA package with 12 pins. My biggest concern is that after viewing all layers on the footprint, it appears that what I think is the solder mask is overlapping between each ball. I used the “land pattern recommendation” to create it. The footprint is given below
The actual data sheet is image is here:
To summarize, my questions are: 1 - Is it generally ok to use the land pattern recommendation without adding any extra size to smd pad sizes? 2 - Is the overlapping solder mask an issue and if so, what would be the proper way to fix it?
Thanks for any input!!
