Crystal symbol designspark
I downloaded library designspark that was probably converted from eagle.
HOwever - i see there are only 2 pins there - but sometimes design experts recomend connecting crstal housing to GND.
So my question - Why is there only 2 pins and not 3 pins on crystal symbols?
Is it ok to leave crystal housing unconnected?
regards
Most through-hole crystals only have two connections.
Yes.
If you want to be able to ground the can then you would need to add a 3rd pad to the component yourself.
But I would not bother unless its for an RF board.
