separate grounds on the same board?
hello,
beginner EAGLE question:
i’m working on an optoisolating board and there are two separate ground connections.
how do i distinguish the two in eagle? is it enough if i add two GND components and name the differently?
thanks,
a
Yes, use two different Net Names and they should then be separate on the PCB.
and by Net Name you mean the symbol i can edit when i right-click on a component and select and change its “Name”
correct?
ali
