CS-E9302 board, boot problem
Hi, recently bought a CS-E9302 board, but the preinstalle Linux 2,6 do not start, when turn on the board (5v regulated adapter, take from the spartan 3E started kit), the red led on (~500 ms), follow the led red off and turn on green led, but the hyperterminal windows is empty, the configuration of serial port: 57600 8N1 - No flow control, all jumper is in the original (?) configuration.
Regards.
5V 1A adapter should be used
Tsvetan
