I am looking athttps://www.sparkfun.com/products/15335 which is SparkFun 9DoF IMU Breakout - ICM-20948. Description says that A la Carte is available for this board:
Need a custom board? This component can be found in SparkFun’s À La Carte board builder. You can have a custom design fabricated with this component
However, I can’t find this component on A La Carte. Did anyone try to customize this component?
It’s probably usually there, but we’ve had issues with the IMU stock/supply chain.
I would expect it to re-appear once global stock replenishes
Thank you very much for the answer. What I need is a combination of ICM-20948 with the ESP-8266 and a LiPo battery charger. Do you think ALC can help me with that once the chip is back in stock?
Yep…we just don’t know when that’ll be
Thank you. Just to make sure, ICM-20948 is not being discontinued, right? Just supply issues?
