I am interested in daisy chaining several qwiic scales into the same Arduino.
Is that possible?
Will the Arduino be able to differentiate between the different qwiic scales output?
Is that possible?
Daisy-chaining won’t work…the qwiic scales all have the same i2c address, so you’d need a mux in between the scales and the arduino/board such as https://www.sparkfun.com/products/16784
You could use 8 this way, or daisy-chain muxes together as well. Please keep in mind qwiic cables usually max out at a few feet for transmit/receive ![]()
