DAP + ARM1176 + ARM966
Hi at all,
I have a cpu with dap controller and behind a (disabled) arm1176 and a (disabled) arm966. I have problemes creating the config-file for openocd…
I’m not sure about the right target configuartion, because dap functions are only supported for cortex m3/a8, not for arm966/arm1176.
Here is the dap info, if I chose a cortex-m3:
target create $_TARGETNAME cortex_m3 -chain-position $_CHIPNAME.dap
Open On-Chip Debugger
dap info 1
AP ID register 0x14770002
Type is MEM-AP APB
AP BASE 0x80000000
ROM table in legacy format
MEMTYPE System memory not present. Dedicated debug bus.
ROMTABLE[0x0] = 0x1003
JTAG-DP OVERRUN - check clock, memaccess, or reduce jtag speed
MEM_AP_CSW 0x80000042, MEM_AP_TAR 0x80001ff0
Component base address 0x80001000, start address 0x80001000
Component class is 0x9, CoreSight component
Type is 0x21, Trace Sink, Buffer
Peripheral ID[4…0] = hex 04 00 1b b9 07
Part is Coresight ETB (Trace Buffer)
ROMTABLE[0x4] = 0x2003
Component base address 0x80002000, start address 0x80002000
Type is 0x14, Debug Control, Trigger Matrix
Peripheral ID[4…0] = hex 04 00 1b b9 06
Part is Coresight CTI (Cross Trigger)
ROMTABLE[0x8] = 0x3003
Component base address 0x80003000, start address 0x80003000
Type is 0x11, Trace Sink, Port
Peripheral ID[4…0] = hex 04 00 2b b9 12
Part is Coresight TPIU (Trace Port Interface Unit)
ROMTABLE[0xc] = 0x5003
Component base address 0x80005000, start address 0x80005000
Type is 0x13, Trace Source, Processor
Peripheral ID[4…0] = hex 04 00 3b b9 20
Part is -- unrecognized --
ROMTABLE[0x10] = 0x6003
Component base address 0x80006000, start address 0x80006000
ROMTABLE[0x14] = 0x0
End of ROM table
MEM_AP_CSW 0x2800042, MEM_AP_TAR 0xe000edf0
dap info 0
AP ID register 0x24770001
Type is MEM-AP AHB
AP BASE 0xffffffff
No ROM table present
dap info 2
AP ID register 0x14760010
Type is JTAG-AP
→ is this a valid configuration?
→ nevertheless: what’s the next step?
Wesche
