Hello everyone. I’m new here and would like to ask for your help.
Do you have a tutorial or example for data integration between the SARA R4 LTE Sparkfun board and the Thingsboard platform?
The Sparkfun example is aimed at the Hologram platform, but I need the data exchange to be with the ThingsBoard. Any help will be welcome.
We won’t have one specifically, but you can follow the AWS ones we do have LTE Cat M1/NB-IoT Shield Hookup Guide - SparkFun Learn (I believe T-mobile works best currently, just based on feedback I see on the forums) and then AWS IoT Integration | ThingsBoard Professional Edition or Search Results | ThingsBoard IoT Gateway
hi Russell
Thank you for your help.
I will definitely follow your advice. I will give you a feedback on the result as soon as possible.
Thanks again.
