Data-sheet information about input voltage
i have recently bought the TOL-21253 (hot air rework station) based on its datasheet it says that it can work for both 110v/220v but when it arrived it was marked as 110v input voltage. now idk if i should get a transformer or trust the datasheet and plug it in. would love some technical help please.
The cable it comes with is rated for 110v
The product page has this blurb:
This rework station even has a detachable power cable so if you happen not to live in North America, you can replace it to fit your own standard plug provided it still uses 110/220V
So, you can use 220v if you swap the plug/cabling
