Datalogger support for ina219 current voltage sensor ?
A few years back you folks offered this board zio INA219 which i use to remotely monitor the battery voltages of a boat during the winter months and upload the readings once a minute to a cloud service.
I was interested in your datalogger product but did not see support for that board, nor a newer version of the board you offer
https://www.sparkfun.com/products/12040
https://www.sparkfun.com/products/retired/15176
Is this sensor on your road map to add support for ? If not can i still use it with the datalogger by writing something by hand or is everything baked into the firmware ? The thought of the datalogger is very appealing not having to write code.
This one https://www.sparkfun.com/products/17873 is supported and might be what you’re after?
Thank you
Looking at that sensor you recommended it appears i would have to cut the positive wire on my DC panel on the boat which is not something i want to do, it also looks like a sparkx product which i know has very limited support and tutorials from past boards i tried. Can it be used like the zio in219 where i just needed a pos and neg wire attached ?
Down the road any chance the data logger could become more open and use a config file vs firmware for sensor support so non SF sensors could work with it ? You folks released a bluetooth nano beacon board awhile back that allowed a programming interface to define a sensor, perhaps something like that for a future datalogger release ?
