Hi there,
I’ve got what appears to be dead EM406 GPS module in my GPS Logger v2.4
The GPS module has worked successfully (i.e. Powered up, GPS LED flashing to indicate a fix, and data successfully logged to the SD card) a handful of times but now appears to be permanently asleep ![]()
The Main Logger PCB still flashes it’s LEDs when powered up, but then they stay off and there’s no red LED on the EM406 GPS module.
There’s definitely 5.2V going into the GPS (or at least coming out of the connector at the EM406 end).
Any ideas? - or is it a straight RMA…? The RF cans that enclose the GPS unit mean that I can’t probe anymore to check for any voltages anywhere insde…
(Even though I’m based in the UK I’ll be in Boulder (well, Broomfield) next week, so I could conceivably return the unit directly to SFE if that’s necessary…)
TIA,
Chris.
