Hi!
I want to use Product DEV-15110 DMX to LED shield to control LuMini LED Ring x 20 LEDs and I have some questions please. May be someone can advise before I order many of them ![]()
- Can I connect x26 of shields in series without a problem?
Total distance must be about about 30 meters from the first shield to the last shield (~1,2m connecting XLR cable)
Each shield needs 5V power supply. OK.
Can I place DMX to LED shield with ESP32 uC somewhere in the middle?
Example:
<Shield0 + Termination R>—lxr——lxr—<Shield2 + ESP32>—lxr—<Shield3 + Termination R>
- All LED Rings must be switched “simultaneously” (just on and off… without complex patterns).
Is any significant time delay at last Shield25 to expect if uC ESP32 installed on Shield0?
Many thanks in advance
