I am trying to set up the DEV 16832. I put the SD card and connected the USB C cable and opened serial monitor in arduino IDE. I am getting symbols as data. I attached picture. I am not able to figure out the issue.
Check that your baud rate is correct.
I tried all baud rates, i am still getting the same error
Double check the COM port and board selected https://learn.sparkfun.com/tutorials/op … figuration, ensure newline is selected, change the baud rate to 115200
That worked! thank you
