Hello!
I am planning on using the USB-C-to-UART (DEV-15096) converter in a project, but I need to know the mechanical dimensions of the whole device. I can measure the width and length of the board using the Eagle files, but I don’t know the height from the top of the USB-C connector to the bottom of the 6-pin 0.100"-pitch female header.
Does anyone know the total height of this device? Or, does anyone know the part numbers of the USB-C connector and 6-pin female header? (I can then look up these part numbers and figure out the height myself.)
Thank you!
