HI,
I was hoping that someone could confirm the height of the JST connector. I"m looking to make a 3D printed enclosure based on the SparkFun-IMU-Breakout-ICM20948 (https://www.sparkfun.com/products/15335 … 1605432499)
I downloaded the Eagle CAD file and exported that to Autodesk to view the STEP file and unfortunately there are no 3D components to measure. I’ve highlighted the JST connector in the Autodesk viewer file and was hoping someone could confirm the height based on the document . (https://cdn.sparkfun.com/assets/parts/1 … asheet.pdf ) . I’m not sure if the height is 2.95mm or 5.55mm based on the side entry component.
Thanks.
Todd
