Do you have dimensions including hole locations for this? It’s not so great to require using Eagle to find these out.
Well I figured I’d download EAGLE in order to do this. I need to make an Autodesk account to use it? Ugh.
I loaded the file in KiCad. The holes are 3.3mm, 20.3mm apart, 2.64mm down from the top edge. Board is 25.4 x 26.7mm
/mike
Thanks. Good to know that KiCad is an option.
