i am using openocd for the first time.
Within openocd’s src code i found a disassembler for arm7/9 instructions.
Is it possible to disassemble code via telnet command interface ?
How can i do that?
Thank you, bo
How can i do that?
Thank you, bo
finally someone who takes the “use the source, luke” serious ![]()
You can diassemble from within telnet using the
“armv4_5 disassemble ”
command.
There’s also a “help” command that displays available commands with a short description.
Regards,
Dominic
Hi, that’s nice. I will use that.
I would like to trigger a breakpoint an then be able to do insn by insn disassembly.
Thank you, dominic.
regards bo
