Display section working fine , but could not able to enter the Set perameter menu from Begining. Every time i need to enter the display parameter and then enter into set parameter function
void lcd_call()
  int button = 0;
  menuOption = 1;
  lcdClear();
  lcd.print("MENU DISPLAY:");
  while (menuOption <= menuOptions)
    button = read_LCD_buttons();
    if (button == btnRIGHT)
      //timedBeep(shortBeep,1);
      menuOption++;
      if (menuOption == 2)
        lcdClear();
        lcd.print("DISPLAY:");
        while((button = read_LCD_buttons()) != btnLEFT)
          Serial.println(button);
          DS_Counter=Display_selection();
          switch(DS_Counter)
          case 1:
            lcd.setCursor(0,0);
            digitalClockDisplay();
            break;
          case 2:
            lcd.setCursor(0,0);
            Display_angle();
            break;
          case 3:
            lcd.setCursor(0,0);
            Display_coordinate();
            break;
          case 4:
            lcd.setCursor(0,0);
            Display_Wind();
            break;
          case 5:
            break;
        menuOption++;
      if (menuOption == 3)
        int button1;
        lcdClear();
        lcd.print("SET PARAMETER");
        button1 = read_LCD_buttons();
        while(Set_Counter<5)
          Serial.println(button1);
          Set_Counter=Select_section();
          switch(Set_Counter)
          case 1:
            if(button1 ==btnRIGHT)
              Set_Counter++;
              //Set_flag=1;
            else
              lcd.setCursor(0,0);
              setDateTime();
            break;
          case 2:
            lcd.setCursor(0,0);
            set_latitude();
          case 3:
            lcd.setCursor(0,0);
            set_longitude() ;
            Set_Counter+1;
            break;
          case 4:
            lcd.setCursor(0,0);
            set_trackertime();
            Set_Counter+1;
            break;
          case 5:
            break;
          //Set_flag=0;
        // menuOption++;
      if(menuOption == 4)
        lcdClear();
        lcd.print("EXIT WINDOW");
