Menu configuration usING LCD SHEILD
Dear all.
I am using Below circuit for interfacing Lcd and keypad.
http://www.freetronics.com/pages/16x2-l … 9jb87pegI.
Basically i completed above code and seems working fine. Now plan to build algorithms such that i configure data like date , time, latitude, longitude . after Modifying Display Date and time On screen with Desired angle calculation. Desired angle might Refer to motor Encoder output0-5v converted 0-360 degree.Now i Need Suggestion On Building the code. The Algorithms Steps. I can modify @ any instant. If change time Desired angle has to change accordingly. After changing It show date and time with angle Desired position.
PLEASE SHARE CODING EXAMPLE FOR SETTING MENUS AND DISPLAY DATE /TIME WITH desire D ANGLE
