DIY Guide: Magnetic Levitation Snail Lamp From A to Z
Hi, in this tutorial, I will provide a detailed and comprehensive guide to help you create a cute decorative lamp in the shape of a snail that can fly and float in the air using magnetic levitation and wireless charging technology similar to what you see in modern smartphones.
You can also make your own beautiful lamp bases using wood, acrylic, or by printing. I also hope that this tutorial will give you many ideas to DIY lamps or other unique products using the technology of the Magnetic Levitation Base or wireless power supply circuits.
I will provide you with everything from the main circuit diagram of the Magnetic Levitation Base, the PCB layout files, the circuit diagrams (transmitter - receiver), and the PCB layout of the wireless power supply. Also, the 3D design model file of the snail lamp.
Wow! Are you selling these?
Looks great.
Sorry, I only show you how to do it, not sell it directly. I have provided full documentation as in the video, you can buy the available module and connect. Thank you for your interest. :slight_smile:
