Dmx and Tsunami Super WAV Trigger?
Hey all. .
Recently I purchased the Tsunami Super WAV Trigger
https://www.sparkfun.com/products/20636
To activate the 4 channel of sound in a sound/light installation
For activating the light fixtures I use a Dmx and Spi artnet
https://www.advateklighting.com/products/e16-s-mk3
A controller that sends Dmx signals and Spi signal and creates a lighting sequence
The part that I still don’t know how to solve is how to sync the two devices (without a third device)
Can i somehow send dmx signal to the Tsunami?
or connect some trigger to a Dmx dimmer that can send 0-100 power?
or a low voltage power supply that connects to a dimmer?
consider that the ADVATEK device does not send midi signal and only plays the sequance in a loop
If you have a DMX device that does on/off that should work. On/off contact closure would be best.
