I’ve seen crazy constants added to the dimensions in the DRC report but not in the billable size except that unless things have changed in the botched website overhaul, it bills you for the width of the outline. I.e. the billable size is to the outer edges of the outline instead of its centerline. So I use a 0-mil line in the .oln file – or I used to until I gave up on ever getting the new website to accept my files. Somehow I doubt you’re using a 100-mil line for your outline… But if you are, there’s your problem!
