DRCbot wedged?
Hasn’t run in 3 hrs (@ 1:55 PDT) and I’ve got a job in the queue.
Maybe there needs to be some sort of watchdog that restarts the bot?
Phil
I can’t speak for the current process; but when I was there; it was a batch job run by cron - so the only way it should wedge is if the power went out ;).
–David Carne
Hmmm… 22 Hrs later and it’s still wedged. You guys must really be snowed in. Last I checked the calendar said it was spring - must be global warming.
thanks for getting it running again.
