Driver not found
Hello Everyone,
I am novice to openocd. I am using Atmel_samD21_explained_pro board.
Open On-Chip Debugger 0.8.0-dev-00175-g8b7acca (2014-10-15-16:59)
Licensed under GNU GPL v2
I am gettng follwing error.
Error: flash driver ‘at91samd’ not found
Runtime Error: /usr/local/share/openocd/scripts/target/at91samdXX.cfg:60:
in procedure ‘script’
at file “embedded:startup.tcl”, line 58
at file “/usr/local/share/openocd/scripts/board/atmel_samr21_xplained_pro.cfg”, line 8
in procedure ‘flash’ called at file “/usr/local/share/openocd/scripts/target/at91samdXX.cfg”, line 60
make: *** Error 1
Hey pinkesh.
What did you try until now?
When looking at that config file:
if srst is not fitted use SYSRESETREQ to
perform a soft reset
cortex_m reset_config sysresetreq
It seems like ’ something’ goes wrong here.
Try to start looking there.
Good luck!
I got this . It solved with newer version of openocd …Thank u…
