Hi i have a question about the minimum and maximum voltage level that my DSP receiver must take. So i have a wireless system .The dsp reveiver take a signal that is downoconverting to 10khz around…
But what about the internal Gains? I didn’t read in detail about these but you should and maybe even experiment to see if your 35mVrms is a problem or not before adding the amp.
at the time i don’t have change the internal gain.it is in the default.so o dB. if i put the maximum 12dB=>
Vout=4Vin. so
vOUT=4*35mvrms=140mvrms= 0,14 VRMS. it is again too low as i understand.
and op.amp needs i think… :geek:
I am still not sure about the minimum voltage level to work effiently… :?: :?: :?: :?:
