I’m trying to find a library I can copy a chip package from.
It’s a 16mm x 23.7mm SSOP (28F320). I’ve been through the entire Eagle library but there’s nothing with the same pin pitch or outline etc.
Any ideas ?
Any ideas ?
…should have also said it’s 56 lead ssop
Why not create your own, that sort of thing only takes a couple of minutes with the Pulsonix software I use.
Leon
You should find it in here
bbarney:
That’s excellent ![]()
Thanks !
leon_heller:
Why not create your own, that sort of thing only takes a couple of minutes with the Pulsonix software I use.Leon
same with the eagle lib editor. takes little practice to figure it out but it’s pretty good.
bbarney:
You should totally stick this up on the OpenCircuits site. I’m sure plenty of people would find it useful.
