I’m working on a PCB layout, but hit a snag with some plated holes I need. I have three Pins that need to be .250" in diameter (yep, a full quarter inch). In Eagle, the largest drill size option I get is .125984". Is there a way to specify a larger diameter drill size for those three pins?
I need the holes to be plated in the final board.
PCB suppliers can’t drill holes that large, they will have to be routed. You will probably have to supply a drawing with the details.
Leon
spiffy_chimp:
Use the Info or Change command to change the diameter. Max size seems to be 0.516024".
Level 46 is for milling.
