sebmadgwick:
I don’t have much experience with PCB CAD software and was wondering if anyone could help me with my problem or expand on the above quote. Essentially I’m getting error for the same problem, is there a way i can modify my problem IC as it is?
Greetings (No Name Supplied),
The production of PCBs is complex. It’s a multi-step, multi-tool
process. Plus. we are trying to hit a moving target as newer
devices are introduced with ever smaller feature sizes (pad
counts. pin counts, pad geometry and spacing).
The earliest automation tools were film printers
made by [Gerber Systems Corp. Which has become a standard
for the PCB industry.
As a practical matter the Gerber data file consists of aperture
data and XY co-ords.
The problem that you have run into (along with many of us) is
that elements in a legal Gerber file may be out of limit for the
production house or data checker (the BatchPCB bot in our
case).
To pass the bot the files must conform to the min geometry
imposed by the service (BatchPCB) and the supplier (GP in
China). There’s no magic or sleight of hand here - it just a
fact of life.
To pass the bot you may have to rebuild your PCB design
using parts that conform to the bot standards.
This may be upset by rotation of ‘good’ parts that create
one or more illegal Gerber data points that trip the bot.
In the long term there are two paths to a solution. (1)
change the bot to detect and ignore fragments that are
illegal but part of a larger polygon. (2) Design alternative
parts for use in CAD that are rotated and legal.
I’m not sure where we stand. Perhaps someone has done
the spade work to get legal parts for CAD, or has tweaked
their Gerbers to pass on a case by case basis? The later
is the fastest way past the problem but also the hardest
to support (revisions, sharing, reorders, etc.).
Comments Welcome!](Gerber format - Wikipedia)
