Hi to you all,
I am trying to use the bluetooth module RN41 in my Eagle project. I did try to creat the footrpint ( device in eagle term) then use it as eagle component by selecting the library then add the component.
I couldn’t create the bluetooth component as it doesn’t use standard grid size (1.27 mm) and the placement of the pad is not regular.
Does anyone know where I can download Eagle library for bluetooth RN41 or how to creat this component using grid with 1.27mm.
Thank you.
Rabengineer ![]()
