Eagle Library
I’m looking for Eagle libraries for Panasonic TS series electrolytic capacitors. The ones in 5.11 use a 6mm lead spacing. I need a 10mm lead spacing. I have never seen a 6mm part. It must be a small value cap with that spacing. While I’m here, how about a MAX668?
In the time it took you to write your post and wait for it to be approved, you could have easily just created the parts on your own in Eagle. It’s easy to do and there are dozens of tutorials just a Google search away (including one on the Sparkfun.com website).
-Bill
tubesman7:
I need a 10mm lead spacing. While I’m here, how about a MAX668?
For the capacitor, this might be suitable: library RCL → CPOL-US → CPOL-USE-10-20
For the Max668, you can get the UMAX10 package from library REF-PACKAGES, or from library MAXIM. As mentioned above, you may have to roll your own part in your library.
I assumed you already did a search, but for most parts you can often get lucky by searching the CADSOFT library site:
http://www.cadsoftusa.com/downloads/libraries/
Jake
Thank you for enlightening me to the location of a suitable part in the rcl library. I didn’t see that one. It is close enough. I will attempt to make a footprint for the MAX668 when I have the time.
