Eagle Polygons
Hey all:
In eagle I’m trying to do some advanced impedance control and am trying to draw a polygon plane that connects to pins. The polygon does not ‘connect’ to the pin and actually renders an ‘seperation’ between it and the pin. I can use the rectangle tool, but not for 45 degree cuts. Any idea on how to better use the polygon tool?
Name the polygon to the same signal as the pins you are trying to connect.
Try using the ‘name’ tool on the plane and name it as the pin you want it to connect to.
Ha, beaten to it…
beaten by 0 minutes, though…
Also, it’s a little tricky to hit the polygon, you have to select the edge of it. It’s one of those “eagle-maddening” things.
