Easy Transmitter and Receiver Pair
I’m search three component that works with together to send one signal to an receiver.
If one transmitter get a 3,3V signal or higher, the receiver should react with a signal on his output with a high signal. The same with the second transmitter. So that i have two signals and the receiver react on signal 1 and signal 2 with an ouput Out1 and Out2.
Have Sparkfun any component to realize this easy wireless connection?
Thanks a lot.
You could get 3 of these https://www.sparkfun.com/products/21293 and program 2 of them to TX when a pin goes above a threshold, with the 3rd one listening to both/outputting downstream stuff
