I am having a vibration issue where the motor I am using is vibration heavily when I decrease the fluid flow rate.
As I increase the flow rate (step count or delay pulse in code) the vibration goes away.
I have tried all Steps (full, half, quarter, and eighth) with the same issue with slow flow rate cause higher vibration.
The motor is small (RP-QII) to which I dont think that is the issue.
What would I be looking for that determines the vibration?
The circuit contains a Stepper Motor (RP-QII) 9V power supply, arduino nano, and the easydriver.
